Learning center
Full site search
    Configuring Approval Flow
    7 mins
    What Will You Learn?
    • Create Approval Flow
    • Approval Rule Settings
    • Add Multiple Approvers
    You may configure the Approval process on all the sheets in Ragic. When an approval flow starts, the system will automatically send e-mails to the approvers. They can approve or reject the process in the Ragic database, e-mail, or mobile app. Besides, you can set up rules for the approval flow. For example, submitting to general manager only when the order amount due is larger than $50000.
    We also support Adding Multiple Approvers in the same step or Setting a Threshold for Approval.
    Related Documents
    Approval flow configuration
    Completed this course? Check the checkbox below!
