Learn Ragic
Using a barcode or RFID reader to enter data in Ragic
Ragic supports both input to field values using a barcode or RFID reader, and generate barcode from values within your database.
Input data with your barcode or RFID reader
You may use the barcode reader to input field values or into the full text search box.
Generating barcode from your values
Ragic can also generate various barcodes based on field values. With the "Barcode" field type, your input will be shown as a barcode automatically after saving. For supported barcode types, please refer to this page.
In case you need to export barcodes as labels, you may use "Label Maker" report.
Top of Page
